ORIGINAL: JDV500
good tip,
will order the gears together. should be this week and i'll get the order out. i'm looking for the site to service the diff's.
thanks,,,
Scroll down the page and you will see him rebuild the savage diffs. Almost the same inside. I used the same values of lube. You could use the same value in the front and rear,
http://ashburg.com/?cat=8
