Cyber
Go to Hobby Lobby International and look at the Three Dee.
To start keep the throws down and it will be mild. You can increase the throws later and have a hot fully acrobatic plane. I would keep away of most of the foam type planes. Had a Mini Max and was a fun plane but under powered and was easy to break and difficult to repair with out adding weight in the process.
Also try Dymond Models, they have some good kits and ARF'S as well. Good luck in your search
Harvard
