RE: New Warhead Evo, shearing input gear pin,
The reverse eliminator does alot for the truck as in reliability wise its just one less thing to go wrong on the truck I did it after i blew the tranny and I also put the sportwerks in it at the same time, since then have not had any problems with it plus when you remove the reverse you can also remove the reverse servo and get some dead weight out of the truck I love mine! Plus the sportwerks is a killer engine and at $125 (with shipping!!) from amain i think its the best deal around. davido666 i'd do some more research on the axial i've been reading alot of conflicting things on them. And also jdv500 when you do the aluminum drag link do the aluminum bellcrank, it takes all the slop out of the steering, and makes it a much crisper set-up. JM2C
Josh
