RE: New Warhead, long time to start...
good stuff, will check it all out.
and yes, i do put my finger over the exhaust to move the fuel thru the lines. my #8 glow plug is new or rather the replacement one i installed after the break in procedure. i need to check the lilttle hole at the pressure fitting for blockage. i'll check and /or replace the glow plug as well.
** new question; is the geared -kwik starter assembly at the back of the engine repairable.? or once it's shot it needs to be replaced.? mine skips randomly now from all the start attempts, even though the truck is only 3 weeks old.
thanks again, for the help...
