RCU Forums - View Single Post - Kangaroo-NitroPlanes-Assembly
Old 01-06-2008, 04:33 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Default RE: Kangaroo-NitroPlanes-Assembly
Finished, all the rigging, final routing of air and servo leads. Mounted a balsa brace to hold air tank in place, mount deans miniwhip in the canopy, cut trimmed & mounted canopy to the airframe. Removed covering from fin panels and fuselage for final epoxie glue assembly. BEFORE the final glue all systems were cheched and tested. Once wings fins & stab glued together fishing wires and airlines next to impossible.
Air fill port and switch/charge jack both installed with 1/32 plywood doubler. The balsa skin is very soft.
A block of balsa stock sanded to fit the inside of the canopy and epoxied in place.
Double sided foam tape (from a Hitec servo) holds the Deans Mini Whip in place.
Flyingwill commence in the spring!
ID:	844055   Click image for larger version
ID:	844056   Click image for larger version
ID:	844057   Click image for larger version
ID:	844058   Click image for larger version
ID:	844059   Click image for larger version
ID:	844060   Click image for larger version
ID:	844061   Click image for larger version
