RE: Should PFs pay less for same benefits as regular AMA members?
Abel the PP is here now, why ya still fighting it?
Oh and are you under the belief that a product or service is priced on what it cost to produce said product? I'll assume you've purchased at least 1 stock certificate in your life before???
You can pull all the numbers out of the air you want, but the program is priced accordingly based on supply, demand and futures and now it's up to the EC and the AMA to make the numbers fit within. But I can assure you the PP program has it's own budget. If the program does not sustain it's budget Abel, I can assure you they will can it as fast as they started it. But only time will tell.
So .... let the clock start ticking.
