ORIGINAL: Bria1
I'd go with the Titans and maybe lower the truck a little too. Didn't you have some Imex Jumbo claws on your Madforce? Maybe see how those look too.
Haha! I didn't build a lot of adjustability into the custom LST shock mounts. The only way I could lower the truck is the limit the shock travel by putting fuel tubing or something inside the shock bodies. Or, I could get some Muggy shocks. They are shorter aren't they? Hmmm.....
Based on the air filter scoop, I can't lower the body any.
I do have the Imex Jumbo set, but the tires are almost the exact same size. They are quite similar in height and width.
