RE: diff setup question
Okay. thanks very much. Okay so question.. i mostly do bashing now.. trying to climb small hills and such.. and occasionally parking lot races.
Recently i had to re-do rear diff and i put in 10K diff fluid there. And front is stock greased diff.
Is it good? Which is heavier? stock grease or 10K diff fluid. What do you recommend i should do for my activities mentioned above, should i leave as is (front -stock greased, rear -10K diff fluid).. or should i do something different?
