RE: Baking Tires?
I've baked them and it worked pretty well. I used a mircowave oven - preheated to 250 degrees C, turned it off and popped the tires in for 15-20 mins. Then i just cracked the tyres off the rim once they were cool enough to handle. If the CA doesn't crystallise immediately you may need to repeat the process more than once.
Suprisingly it didn't stink the house out as i expected it to, athough i did wash and dry the tyres thoroughly beforehand.
