ORIGINAL: graygoose
ok just recieved a dx7 and I AM HAVEING A HARD TIME WITH THE BINDING, USING EVERTHING THAT CAME WITH THE SET, BATTERYS ARE FULLY CHARGED, WHEN i SWITCH ON THE RECIEVER BOTH RECIEVERS BLINK, THEN I HOLD THE BIND BUTTON ON THE BACK OF THE TRANS AND SWITCH IT ON , AFTER A FEW SECONDS BOTH LIGHTS GO SOLID, EVERYTHING WORKS AT THIS POINT, BUT WHEN I REMOVED THE BIND PLUG EVERY THING IS LOST. IF THE BINDPLUG STAYS CONECTED THE SYSTEM WORK UNTILL THE RADIO IS SWITCHED OFF, ANY HELP ANYONE?/
G'day Mate,
After you have it binded, do you turn the RX switch off, & the TX, then remove the bind plug, & turn it all on again, TX first, then wait 5 seconds for the TX to acquire 2 channels, then turn the RX on, try it this way & see how it goes.
I have never had a problem with mine, or my new DSX9.
