RE: Ignition Battery Switch
Hi Larry,
That is true but it is also the size of a JR heavy-duty switch which I think Doug was trying to avoid. The Badger switch uses the pin switch to turn on/off some FET transistors that actually pass the current. The pin switch does not pass any current itself.
