RE: New Great Planes Revolver
Ahook, is the loose wire that you soldered in the servo, tx or Rx? if it is in the servo, just replace the servo. If it is in the Reciever or Transmitter, you really need to send it back the Futaba service center. It takes about 10 days to get it back. You need piece of mind because if something stops working in the air you will loose you airplane and or engine and internal components not to mention that it could be dangerous. I hope that you can sort this one out. I have had servos starting to act up because of moisture in them and when 1 servo starts acting up it seems to affect the other servos too in the form of chattering. I almost acts like interference.
Jeff
