RE: dual elevator servos question
some addtional help:
when using 2 servo on the same moving surface - ELEV- it is best to make one servo as the master and the 2nd one as the slave.
set up the master on the ELEV CH as you allways do.
than setup the other on a MIX without a SW - u want it to work alltimes not deppnding on a SW!!
when setting up the MS servo - all should be in NORMAL - to center the ELEV use the pushrod mechanical adjusments ONLY. than the same way the SLV servo - mechanical adjusment only.
after that u can trim,subtrim ect digitally.
mixing: go to the 1st MIX,if free, and choose the appropiate channel for the MS and SLV servo.
