RCU Forums - View Single Post - Hitec HS-475HB
Old 01-27-2008, 10:54 AM
jeffk464
Default Hitec HS-475HB
It seems to me that the hitec HS-475HB is about the best standard servo going. Its cheap, high torque, ball bearing, lighter then almost all standard servos, seems to center well, the only downside is the .23 sec transit speed. Some people say that the karbonite gear train can't handle gas engines or strips in large plane applications, but I fly all glow models under 12lbs. Just curious what everyone's opinion is on these servos.
SPECS: Speed: 0.23 sec/60° @ 4.8V
Torque: 4.4 kg-cm (61 oz-in) at 4.8V
Length: 38.8mm (1.52")
Width: 19.8mm (0.77")
Height: 36.0mm (1.41")
Weight: 40g (1.41oz)
