ORIGINAL: Canuck1
I have the wing tips dry fitted. Fairly snug............just not sure which epoxy to use to glue them on. Either 30 min, or should I go with the polyester resin, that I used for the bracing in the fuselage.
After they are attached I will sand the leading and trailing edge to shape.
Craig
Remember that polyester resin will melt the foam!!
