A while ago I cut out all the pieces up north except for the sides, you can see all of this in the first picture. In the second picture you can see where I started with thin C.A. glue and switched to thick. The engine is a Magnum GP .40, I'll be using a Futaba 2PH controller. I pretty much have the rest of the build figured out. Rite now I'm starting to glue the bottom to it(strips). Hopefully making this thread will keep my progress going, I have stretched out the time so much already(6 months + [&:]).
Well, here it is... It's going to be a little different than the original plans but not by much...
