RE: Stock HBK2 lipo batt and motor getting HOT
dicharry:
You need to first answer Jasons question. To assume that the factory will produce a good overall system is a little naive. They industry is getting much better overall, but there are still some almost unworkable systems out there. If you have a hot running system, something is not sized adequately, probably prop, motor and controller. To find out what is what, your going to have to buy or borrow a "Watt Meeter", best buy cause you need one to keep your equipment alive. The watt meeter will tell you what the demand on the system is in amps. If the prop is too large, and your amp draw is over specks, you can go down a prop length or pitch, or both to bring the demand down to reason, thus reducing system heat. Is this a brusshless motor, or the typical cheeipe brushed motor with gears? To really help, we all need to know. A deans connector, large red ones are much more efficient than most others out there and should become standard on your systems.
1. motor type, size and max amp rating.
2. Prop size
3. Controller size and type
4. How many cells in your lipo, what c rating
