ORIGINAL: davido666
The only problem I could see is you need air flowing over the engine head or if you don't you will overheat the engine and damage it. You should have a large fan blowing across the truck.
That was just the test to make sure it worked the way I thought it would. You're right. There will be a fan there during future use!
