RE: XTM Monster MT First Impressions
Only thing that sucks on an MMT is the wheels..........as for the brakes if you know how to set it up properly you can make it endoe pretty easy...........Lock tight on the nuts for the wheels???????? CVD's to expensive??????? compaired to what HP CVD's on the Market????????? if the throttle gears in the servo are made of plastic what does moisture matter??????????? Pull start cords don't break unless you pull them all the way out on any model. OWB is the same as any SH engine and its set up like almost all HPI, Traxxas, or CEN oops, maybe because Golden Lion makes engines for them...I don't know [&:] If XTM is ever to become a Star again it will be because of the MMT.
