RE: What Engine Other Than Jett/Nelson?
yes im leaning to the the TT .40 Pro...
or maybe even a smaller higher rpm webra?
hmm maybe i need to post this into the pylon section...
kinda new here did not realize so many categories here with so much info geeezz its massive!
might find what i need to know from some research on the forum. gonna do that when i get the time.
just want to know what will be better pylon performance lower rpm bigger prop?
or higher rpm smaller prop? 2 pylon 800 ft track...
i hope to get this model under the listed flying weight if possible...
will get the kit soon and get weights on the parts and i will know more about that.
i realize there is similar type airplanes that are lighter ...
im interested in this because the fuse is all fiberglass.
straight and true no fuss i want this thing to fly like its on rails!
so I'm willing to sacrifice a bit a speed for handling if i need to.
