RE: Help- Confused between Hitech optic 6 and Futaba faast spektrum
As aeajr says, about the only way either the Futaba or Spectrum will loose lock in the air is when a negative voltage glitch hits the receiver. As long as your battery capacity is adequate and you have adequate quality (current carrying capacity) wiring and switch, no problems.
