RE: Bob Cat Copy Falcon 120 Jet
Hi Guys,
Thank you so much for info on servos and fuel set up. I am also new to turbines, I will be using a P70 with my falcon. In process of researching all the components needed for safe operation, since this is probably my only chance of flying a turbine (won't be able to do it again if I crash). Are you guys using redundant power supply for your receiver/servo set up? What is a good cost effective means of making sure the power supply or the electronics function with out problems.
Thanks again..
Serj
