RE: 90" P38 with two YS110?
should be a very interesting build,,, you might want to make sure you can squeeze at least a 13 or 14 inch prop between the pod and the main cockpit. ys 110 on a 14x12 is good speed,, some have used the 13x13,, apc.--- good luck.
