I've got a feeling the reason you did not get much interest in this forum is because it has been hashed over a million times here and at FG. So I will give you my opinion. Hitec HS-5985 on ailerons and elevators and HS-5955 on rudder. You can go cheaper and still fly it, but why save a few dollars on a very important part of your setup. HS-5985's are $73 each and HS-5955 are $89 each at Donalds hobby. If money is no object go with HS-5955's all around.
http://www.donalds-hobby.com/Prod/Scripts/default.asp
