HOW TO BUILD A "HAULER" Part 1
A Hauler is best built from salvaged parts. Stuff that would normally be "Hauled away" Hence the name "Hauler" The next event you attend keep your eye open when a "Buyer" looses a plane the remains usually go in the trash,they don't fix anything,so ask if you can have any pieces that are repairable. Check out the photos A tail from a Predator with no damage to the flying surfaces All you have to do is clean off the fuse remains and you have a set of flying surfaces that are all covered and ready to use . Almost as good as buying a ARF The next part will cover the building of the "Booms"
