RE: Redcat Racing Tornado Thread
how far did you push the one way bearing in? on the website it says you have to push the one way bearing in further to make it work with this engine, it says the one way bearing will not contact the shaft enough and needs to be pushed in. It does not say how far to push it, is it supposed to be flush where the brass ring goes or should it stick out further than the brass ring?
