RE: Golden Skies RC - Bampf 3D (Build Thread)
The next step was the wings. I used 30min. Epoxy to join the wing halfs and also dimpled the wood with a screwdriver to assure a stronger glue joint.
After the Epoxy cured, the clamps came off and it was time to test fit inside the wing saddle.
Next, I test fit the belly pan and marked out where the wing bolt plate & belly pan needed to be glued. I didn't attach those yet because it isn't anything structural that needs to be glued on like the tail.
Then I got the HS out and aligned it to the fuse to mark. The next step was to dimple with a screwdriver so glue would bight better to the joint.
