Sticky Swash
New to the HBKII, I am running HS55's on the swash and am finding the heli seems to have a delay/sticky swash in the pitch aspect. I have changed the feathering shaft for the harder one from US hobby. Running woodies with the blade grips somewhat tighter than the machine came. (grips still rotate freely and smoothly). Not sure what the potential cause may be. There is a slight amount of slop in the HS55 gears (backlash) and some play in the swash itself. Holding a hover, I can increase the pitch/throttle slightly, no response, again a bit of increase, no response then suddenly it will climb. Same thing downside.
Got caught at the park this AM from about 15' (didnt increase pitch fast enough?) and find the heli wont fly very well after you scrap a lot of the plastic covering off the woodies!
Anyone have any suggestions would be greatly appreciated.
