"Stacking" mixes on the DX7
Hi,
I have a question regarding mixes on the DX7.
Say i have a 3D model with dual elevator servos and also want to mix out some knife edge coupling.
I know that you can use Mixes 5 or 6 with the trim include feature for dual elevator servos, easy to do.
But what if i use one of the other mixes with Rudder as master and elevator as slave (to add some up elevator with rudder).
I know the servo connected to the Elevator channel will move, but what about the other elevator servo that is mixed from Elev --> Aux 2?
Will it also slave from the Rudd --> Elev mix or will i need another mix with Rudd --> AUX2?
