RCU Forums - View Single Post - Outlaw Build E/Lite
Old 03-15-2008, 07:04 AM
c/f
Default RE: Outlaw Build E/Lite
Next up was rudder servo to clean up drag I like to combine draggy areas versus spread them out, so I needed to drop the rudder servo in its mount and slit lower fin to allow for servo arm. I had to use a low profile JR9011 servo here, by removing gusset on sero plastic I Ca a peice of maple wood to act as a clamp once servo was installed from inside of fuse to give a nice flush mount outside surface. Using a 1" arm on 3/4" horns it provided the recomended throws.
ID:	903790   Click image for larger version
