50CC Composite ARF what regulator?
hi,
I am currently building a DA50 Powered 78" wingspan composite arf extra. I am using 6 Hitec Digital servos Model HS 5645MG.
I am also using a Spektrum AR9000 Reciever, as i understand that the spektrum gear is voltage sensitive, i plan to use 2 Thunder power 2cell 2100 mah lipo packs through 2 regulators and 2 switches into the 2 battery ports in the reciver.
However i saw your Sport regulator & the Super regulator. considering my setup what should i do,
1) Run 2 seperate regulators & switches
OR
2) Run both the lipo packs through 2 heavy duty slide switches through the dual regulators mentioned above. And if so. then considering my setup, which of the 2 regulators would you recommend.
Please advise.
Thank you & Regards
Ravi Kothari,
Mumbai,India.
BTW i am ready to place my order with Airwild, just waiting for your input here.
