RE: King Motors Baja Review with pictures
The rear dirtbusters arn't exacty the same as the official HPI ones, obviously there's no HPI brand on them and the thickened rubber area for an exact fit with the HD rings is not there, these tyres are a copy of the weaker 1st generation dirtbusters (the ones that ripped real easy).
The other issue is the plastics, they weigh more because they are a different type of plastic, since HPI uses high impact nylon then chances are the cloners arn't using high impact nylon. Likey an ABS type, tamiya use alot of plastics that arn't UV resistant and basically overtime become brittle under sunlight (lets hope they've done their homework)
The plastic looks rounded and lacks definition because its mould was based on using an original HPI part, thats how copy moulds end up, sort of like a photo copy - good but lacks the clarity of the original.
I'd be intrested in a photo of the inside of the wheel, to see the webbing, HPI later re-enforced this area with extra webbing to reduce the wheel flex, would be good to see which version of the wheel the cloner copied.
