RE: foam rc airboat fiberlass????
its the pink insulation foam that i got at home depot. is that the porous foam you were talking about? and would i be able to get any type of epoxy? and would 1 qt be able to cover it and do the glassing for the entire project. and for Strankon, what are you going to suppoer the genine stand with? i dont think that the fiberglass shell will be strong enough and you do need some weight to hold the boat to the water cause of all the air that goes under the boat. some weight is good. but i will have photos of what mine looks like and what i have done to it so far. thanks guys.
