fuel
It may run a little hotter, but with the add. of nitro...you can actually run it a little richer and have the same performance. I used to run 30% coolpower in my savage, then I went to 20% when I got my picco in it. I did notice the picco had more power with the 30%, but not a big diff. between the 20% and 30%. I hope this helps. Just run the 30% and richen up your needle after you get it started. You won't notice a big change in needle settings anyways.
