RE: 1/6 Scale F4U Corsair Group Build
Tail wheel
It''s time to begin documenting the tail wheel build.
In early 1944, a longer tailwheel leg was installed to raise the tail, and reduce the directional stability problem. This also give the pilot better forward visibility for takeoff and landing.
The tires came in two types - hard rubber and inflatable. I''ve attached pictures to show the various types.
I will be using the shorter version because that is what the subject of my model had. Earl Aune originally made mine but most of the others here are making their own and will show their work.
Sources:
f4ucorsair.com
Vought
Tailwheel pictures (L to R)
Long, hard rubber
Long, Inflated
The short version
The short version per Vought engineering drawing
