ORIGINAL: SitNFly
ORIGINAL: craigteffe
Wanted to start a thread for my new Hybrid Edge 540 build. I have had one already and crashed it 2 months after i got it built due to a battery, regulator, or switch problem culprit is still unknown.
I liked the plane so well i wanted another, I will be using the following equipment
A123 batteries-eliminates a regulator and charge time is very low, one for ignition and 2 for reciever.
5955 on ailerons 5985 on elevators and 5955 on rudder, oh and on the throttle i will use a 5245
24 oz dubro tank
heavy duty dubro hardware, with a little modification here
I have an XPS reciever and a Futaba 9C radio
The plans say to build the fuse sides out of 3/32 and you have to edge and end glue 6 pieces together to form the sides. That is where I am at now.
What engine will you be using? Good thread; I''''m interested in one of these.
I will be using the DL 50 in it with a Jtec wrap around pits muffler
