ORIGINAL: Kevin Matney
Zero-lift angle of attack is -0.15 degrees and Ideal of attack is 1.04 degrees according to CompuFoil 3D.
Find out were you are at like FW to wing then wing to tail, and then work out what is the best way to go is first before you do any thing.
What you need is the Zero lift for all out speed, you get the other in a trun. what that means is how hard you can turn with the most speed
