RE: seagull models
Hey!
I need some help. I have a seagull yak 54 63" wing span. The CG says it's 7-8 cm from the leading edge of the wing tip.
Would that mean the outer wing tip or near the plane. The reason I ask is that when I setup the CG the plane flys tail heavy with it set to the outer wing tip. So it's now seem to be a trail and error thing to figure out the CG if anyone has delt with this could you let me know Thanks!
Mike
