Some questions....
Went to maiden y P-47 yesterday but on TO power the flaps inadvertently deploy. I am running an airtronics 2.4 system. I was led to believe that this omitted any possibility of interference so I placed the RX directly behind the ignition unit as it was ergonomically convenient. My flap servos are Hietec mighty minis (analog) the rest are digital. I thought that this in itself was a problem but was reassured that the airtronics RX could handle it. Today I have moved the RX back about 10 " away fro the ignition and engine, I have yet to test it. Just wanted to know what you think. Also my G-26 ei began to sputter when given gas yesterday. Not tuning issue, tried to blow down the carb but soe kind of check prevented it. Last night took it apart and cleaned it thouroughly. Just curious if anyone knew of any other possible causes for this, Including the most likely.
Zenoah G-26ei
Airtronics RDS8000 2.4 on 6 volt system
Thanks and best regards. Peter
