RE: too much trimming for a showtime.
Incidence is the angle between the wing's chord and the longitudinal axis of an aircraft.
Not sure about the Showtime 50 but the 90 is supposed to be zero degrees. As I found on my 90, it is quite possiable one wing panel is more positive than the other. To check this you will need an incidence meter.
