You guys talk like you never take any risk, You all take risk when you put your plane or copter in the air so don't play this your are irresponsible
I suppose I should have said "it would be irresponsible flying in this configuration at a busy flying site with innocent bystanders"
If its between you and the cows, have at it. You asked if it was a good idea, we told you no. Good luck with your new plane.
As for risk taking, well you may have a point. Afterall, I used to run into burning buildings when most people were busy running out
