ORIGINAL: fallingleaf
Great in that case I am sorted as I have a TONNE of greatplanes 3/32 tubing! How is this engine without a pump is the fuel tank is up front? I have heard it generates quite good fuel draw without a pump. Planning on using a 10oz tank with it (plenty of space up front in the ultimate for a bigger tank). Just curious about the pump in terms of if the plane ends up a lil nose heavy and have to move the tank back a wee bit!
don't forget to balance with the tank empty! an empty tank will make lil to do difference in cg.... (if moved only by an inch or too..)
Steven
