is it hot or cold there. at night its chilly right and during the day hit as anything. like florida but with out the humidity.... so change youhave to do a little depending night or day runs.
but the lsn is for the punch, the begining past when you gas it. the hsn is for the top speed part. so it punches and then bogs its the hsn... it slow starts and bogs then speeds up its the lsn.
yes start flush and turn slight turns clockwise i believe, like not more than a qaurter turn at a time and may take few start and stops...
what engine? this .28 has been tricky for me. i used to run only the .15 pro and the .18 engines, so this is more effort to adjust. but once there all other adjustments are minor they say.
hope this helps. any correct me if i am wrong.
if it's the sh .28 check the ling for more info.
http://www.happysale.dk/images/SH28.pdf
