Just about any of the standard ground recievers will work, The one thing I will suggest is if you don't have the aluminum upper plate you should get one. The reason being that you need to get the battery away from the reciever. The cheaply made batteries that all come from China splatter electric impulses that interfear with the RF and can cause problems.............including run away even with a failsafe
