RE: Quick Setup Tips for the 9303 JR
How do you set up the left slider to control the throttle trim on the 9303
to prevent the slider from affecting the throttle above half stick.
For example.....with the stick at full throttle, moving the slider will
change the throt channel position.
Anyway....if you have any advice on how to set this up I would be most
grateful.There are probably many ways to do this.
Here is one. Go to PMIX 6, LLVR->THRO
Scroll over and enter -25 for POS 0 with slider pulled to you. Next scroll over to THRO STK and enter 20 (or whatever point half throttle or below where you want the mix to stop working, 50 is mid stick)
OK, now go to PMIX 5, LLVR>THRO
Scroll over and enter +25 for POS 0 with slider pulled to you.
Go back to list menu and hit "monitor". You can view whats going on with all of this stuff directly. It does not disable the throttle trim lever but effectively gives you the left slider as a secondary throttle trim.
You can adjust the level of sensitivity of the slider by adjusting both the -25 and +25. What PMIX 6 does is cancel out the PMIX5 mix for every point after you designate your THRO STK point.
Double check your control linkage end points or use the TRVL ADJ function to set your throttle end points as needed.
Hope this helps,
Don
