Expo and dual rate
@uciflylow : I agree with you about dual and expo. I always found it a bit contradictonary, having both on a radio, although lots of them have both, like the MPX Cockpit and the mc 3030.
I figure that when having expo available, you really don't need dual rates. With your expo set up correctly, all you need is move the stick more to get those big deflections, and as long as you don't yank on the stick, you have the reduced throws, according to how much expo you dialed in.
Michael
P.S. The Multiplex Cockpit also accomodates everything mentioned so far, expo, dual rates, servo reversing and mid point adjustment, and if I remember correctly, it has 2 timers.
It also has digital trims, although these are controversial.
