RE: Rebuilding worn out engines?
Yes it is worth rebuilding worn engines. Only damaged engines may no be worth it, Bent cranks can do a lot of damage to the cases. Piston, cylinder and bearing replacement is common in race engines where high nitro content is used.
Cheers
