RE: Futaba 6EX mixing 7 servos?
I do not think that you can mix your flaps and ailerons as you have stated with your radio. You typically want your flaps on one channel and they deflect with the movement of a switch. If you were to mix in anything at all, it is usually a little down elevator to compensate for the climb induced by the flaps coming down. Good Luck, Dave
