RE: Nitromodels PREDATOR RQ-1B
Well First up mod HAS to be steerable nose wheel...otherwise how is one to track it on the ground?..but instead of installing another servo, I have installed a slightly higher torque servo in the existing tray a brought both sides of the elevator back to 1 servo, and the other is used for nose wheel and lower fin actuation..(big word).Also I liked your removable wing mod so I did that. I am taking picture for the thread and will post later. And after the flight tests are done, I will start work on a bigger plank for AP use..dunno if I will go with the same layout thou...I was talking to Joe Wurts about layouts/wing platforms on the weekend, so will see what he says...one better to ask huh?
Brownlab...if the means a spring wind in the leg, than yes it does.
