ORIGINAL: Mttvannest
I think the hobico charger will work for my needs. i just need to know it the charge rate on that 4th port is ok. Can i charge a 1100mah nicad rx pack overnight at 100mah rate? All of the other ports will charge at 50mah which is the same as my standard wall charger that came with my radio
100 ma charger will charge a 1100 ma pack in 11 hours. 12- 15 hours is still on the safe side.
